Car pulls hard to either side
Old 12-27-2009, 10:40 AM
  #21
Siggy's Avatar
Similar theory to billman, whats your specs on your tires? could be them just gripping every bump or crack and pulling your car in that direction, specially if your running wide tires all around and such!
Old 12-30-2009, 07:44 PM
  #22
warrenk05's Avatar
i just checked today and my tires on my passenger side are pretty worn and my drivers sides arent. thats probably due to my car pulling to the right.? i think ima get a new set of tires soon. does anyone know what size i can get that would be better than what i have??
Old 12-30-2009, 09:58 PM
  #23
warrenk05's Avatar
i have 4 215/35/18 tires would these fit better?
Old 12-30-2009, 10:26 PM
  #24
9K-S2K's Avatar
Get new tires and when they rebalance them your shiftiness should go away. Are you on stock suspension? When lowered the bumpsteer is more pronounced.
Old 12-31-2009, 05:59 PM
  #25
warrenk05's Avatar
alright thanks guys ima look into some new tires
Old 12-31-2009, 10:06 PM
  #26
Siggy's Avatar
215s on the rears?
Old 12-31-2009, 11:19 PM
  #27
kamal's Avatar
have you checked your tire pressures? make sure they're even in the rear, as differences in the rear will cause the limited slip differential to cause the car to pull one way or the other under acceleration.
Old 02-26-2010, 02:06 PM
  #28
warrenk05's Avatar
fixed the problem, it was the toyos, i changed it to falken 912s and it was all solved.
Old 03-02-2010, 10:09 AM
  #29
Jimmyh3116's Avatar
When I bought my S last year I had this same problem. I'd hit a small bump and it felt like the rear of the car would pull left and then right very quickly. I took it into the dealer and there were some bushings that were worn down on one of the crossbars, the sway bar I think. They replaced that and I have not felt it since. Goes to show a symptom like this could be a lot of things.
sars
01-23-2009 06:24 AM
DDonovan
11-24-2008 07:35 PM
jsebastiant
11-13-2006 06:20 PM
s2000from canada
02-19-2006 09:50 AM
ZaToIChI
12-07-2004 06:56 AM
Quick Reply: Car pulls hard to either side
