Car pulling abnormally?
I noticed that just recently anytime that I amg 45 or faster if I floor it the car will pull hard to the left hand side, like almost 25 30 degrees. Enough that I have to correct the wheel to avoid chaning lanes. When I just go down the road at a constent speed there is no pulling. If I floor it and then let of the gas all the way the car pulls to the right hard. Same thing if I shift from a higher RPM range the car will pull hard to the left.
Its an abnormal pull to the side, the people from Norm Reves are trying to tell me that it is torque stear, some how I dont think thats what it is.
Any ideas?
Any ideas?
You should reconsider your dealer if they are giving you that kind of analysis of your problem.
They said "they checked the tire pressure and aligment already and it probably normal torque steer", and you checked the tire pressure and it was off. Come on, how hard is checking tire pressure? They didn't check anything and just gave you a go away answer. And torque steer? I hope they know that a S2000 is rear wheel drive!
