Car Pops when Idling
Old 07-29-2010, 03:57 AM
  #21
ljsimp's Avatar
If you are mechanically inclined a valve job is fairly easy to do there are plenty of articles written on this. If not then dealership is a piece of mine.
Old 07-29-2010, 11:03 AM
  #22
03_BB_S2K's Avatar
Originally Posted by Dumas2k,Jul 28 2010, 04:48 PM
ok just got back from autozone had 2 cel codes
1.)p0410
for the intake
New to Me.(After Installing The test pipe.)
2.)p1399
Random cylinder misfire
Blocked EGR passage
Valve clearance out of range
There you go. You have multiple codes. Not trying to be mr. know it all or anything but these things come with experience and hopefully in due time you'll get the hang of it too. If i were you, i would get a good mechanic or dealership to get the valve job done. I mean it's nothing hard to do but you want the job done right once and for all. If you know of any good mechanic who can do it for you just as good as the dealership then by all means go for it. Keep us updated with the progress of things.
I have heard of people having valve clearance issues but i never knew it could cause cylinder misfire.
Please someone chime in to confirm whether what i have just said is right or not
Old 07-29-2010, 12:54 PM
  #23
Dumas2k's Avatar
ok yea im having a member from our area do it this sunday, he has worked on alot of s2000 and other members have vouched for him
Old 07-29-2010, 07:04 PM
  #24
Wildncrazy's Avatar
Popping on the exhaust side is usually an exhaust leak somewhere.
Since most ecu issues turn out to be a bad ground I'd clean up every ground you can find.
If you are looking for a code read the go to your local Autozone or other auto parts store, they will read the codes and tell you what they mean.
Old 07-29-2010, 07:27 PM
  #25
turbo_slug's Avatar
1.)p0410
for the intake
2.)p1399
Blocked EGR passage
P0410 is airpump related. It shouldn't be related to misfiring...
P1399 is random misfire (this code alone is useless. you need the freeze frame data for it)
as for EGR...the s2000 doesn't have an EGR system
Old 07-30-2010, 03:48 AM
  #26
NFRs2000NYC's Avatar
P0410 is secondary air injection...meaning, airpump. It's not your intake.
Old 08-01-2010, 10:15 PM
  #27
Dumas2k's Avatar
Got a valve adjusment today, it looked ok. @ valves were loose, also did a compression check 240, 245, 240, 250. The car still pops around when im idling. It does it alot when i first start up the car, but after drving it a while it doesnt do it as much, and when i apply a gas on the pedal it would shake the car forward and back almost like a misfire in low rpms 3k and under, But after that till 9k its smooth
turtleesss
10-28-2016 05:57 PM
XBMAX
08-11-2013 11:36 AM
lriver1004
01-02-2013 05:34 AM
Passions
09-27-2007 05:13 PM
DarkEarth
04-01-2006 12:41 PM
Quick Reply: Car Pops when Idling
