Car kicks out of first
So this has happened to me twice now. Im in first gear and i get on it and aroun 6-7k the car kicks out of first and grinds horribly. I heard it might be the tranny fluid. This happened to n e one else?
that's never a good sign. I just had that problem, ended up rebuilding the entire transmission.
that means your gears missing a tooth or worned down.
I would also assume there is a problem with the 2nd gear and its syncro.
good luck, it's a PIA for sure to have gear pop out problem.
sometimes you could fix it by adjusting the clutch line, but it's a slim chance.
most likely your transmission gears.
