car idle dies at a stop
so lately my car dies when i come to a complete stop, it also bogs when i try to take off it feels like its misfiring. lately it seems like its burning more gas then regular. Its not throwing a cel code either, i have read the thread on here about the stuttering and stalling problem but still cant figure it out. So far i have done a map whack, that didnt work i changed map sensors i cleaned my IACV cleaned my throttle body and still nothing. i hooked it up to a obd scanner and says the car is running lean i have also changed the spark plugs. any ideas would really be appreciated thanks
Check your air filter to make sure it's not clogged.
But it may be a case of bad gasoline. Have you run multiple tanks of gas and the problem has been there for all of them?
sounds exactly what i had a problem with. I did a map whack and replaced the map with the new zip tie one, that worked for about 3 months and then i started to feel it coming again. It only acts up very seldomly and usually in hot and humid weather, so i usually just blow it off and blame the weather.
Other than what negcamber has suggested i got nothing =(
If you do find a fix though please share
I experienced the same thing last year, it used to happen on a hot day or when the engine was hot and what worked for me was TB coolant by pass. Try the link below, it might help.
https://www.s2ki.com/forums/index.php?showt...&#entry14815576
