Car hard to shift into gears..
its also possible to have a worn clutch. there are numerous reasons the car might be hard to shift, 1st I would see if there is fluid in the clutch reservoir, then the inside of the master(inside meaning the inside of the car)
Thanks for the replies! I checked the master and slave and there are no leaks from master/slave cylinder under or inside the car. I checked the reservoir and it seemed a tad bit low. I filled it up and the clutch feels great now! I'm glad the problem seems to be solved, but would ~4 ounces of missing fluid in the reservoir really make a difference like that?
Hopefully I won't have to worry about this again anytime soon, but I forsee a full bleed/new fluid change in the not too distant future...
Yeah mine had the same problem, I thought I needed a new clutch but turned out that it just needed fluid! You might want to check it every oil change or so cuz mine gets low every oil change and I looked behind the pedal and mine has no leaks I have no Idea where it goes
