Car goes to shit at Vtec.....?
I have one, that Ill be working on here in the next few minutes. I don't think this is gonna do the trick, but Ill try it first. Just wanted to get something up for when I come back.
Problem: On the way home, I was just driving along and went to higher RPM's and as it hit Vtec....it bogs down and just won't go. I don't think I could get it to 7K if I tried.
Any Ideas
Any Ideas
Gonna check:
Vtec Solenoid.....screen
Anyone know how to check it with a test light? will it be ":hot" all the time or only when kicked in?
Guess I could try a map wack.
other than that....
other than that....
If you can describe it as stumbling at high rpm it could be a simple ignition cut out. Check your plugs for any fouling or incorrect gapping. If they are old it won't hurt your wallet to replace them anyways. A weak coil, dirty/malfunctioning injectors, or even a dying fuel pump could cause a similar symptom.
Yesterday and the day before NPs last night, we were ripping it through Nashville.
I wake up this morning to head back home and I get a "bog" effect at Vtec. Car runs fine as long as your not trying to get it into vtec range.
Originally Posted by Spec_Ops2087' date='Mar 25 2007, 04:32 PM
Stupid idea, but it was warmed up right?
and that's not a stupid idea.....but Im not that much of a n00b
