Car goes to left once gas pedal is released in high speed
Old 07-17-2012, 01:46 AM
xchino's Avatar
Default Car goes to left once gas pedal is released in high speed
Hello everyone, i need some professional help from you guys. I just got my car 2 weeks ago and i mostly drive short distance without using the freeway. Yesterday, i went on the freeway and my speed was like 71mph and when i release my foot on the gas pedal my car eventually sways or goes to left. I tried multiple times and i have confirmed that the car is acting up this way. Is this a tire pressure issue, alignment or something else.
Old 07-17-2012, 01:52 AM
dwight's Avatar
Why don't you check the tire pressure so you can determine if it is a tire pressure issue?
Old 07-17-2012, 03:00 AM
INDYMAC's Avatar
ditto-check tire pressures are equal all the way around when they are cold.
Old 07-17-2012, 04:38 AM
EOE
EOE's Avatar
Tire pressure most likely.
Old 07-17-2012, 07:31 AM
xchino's Avatar
I thought so too, once i get my car back then i will definitely check on the tire pressure. Thank you
Old 07-17-2012, 09:38 AM
Kreapin's Avatar
keep us posted, curious to see the end results
Old 07-17-2012, 09:57 AM
Former Sponsor
Moddiction's Avatar
It's gotta be tire pressure. Very common issue people post up. 99% chance it is.
Old 07-17-2012, 10:10 AM
apme123's Avatar
make sure the tires are not too old, and have roughly the same amount of wear, I would do new tires all the way around, proper tire pressure mount and balance and a quality alignment.
Old 07-17-2012, 10:27 PM
xchino's Avatar
I will, thank you again guys. I didnt know that s2k's are that sensitive
i should be getting my car soon hopefully by tom.
Old 07-18-2012, 06:26 AM
davidc1's Avatar
But our cars are extremely sensitive to differences between right and left tires. Meaning tread depth and tread pattern. I had bought some rear tires used ,very high quality tires. The tread depth was one mm difference between the two. The tire wear patterns were slightly different. Not much.
Caused the exact same issue as yours.
Are your rear tires cheepos? Were they new when installed on the car?
Quick Reply: Car goes to left once gas pedal is released in high speed
