Car electric problem?
long story short...
Car was running perfect... then doesnt wanna turn on... battery dies... got new battery... start up after 2 long cranks... ran good and perfect... parked home... now same thing... but its doing just 1 thing different... when it cranks.. dash lights flickers... car havent EVER done this before...
uploading video now
uploading video now
Voltage is too low. It sounds like it is cranking way too slowly. Charge the battery up and start the car. While it's running check the voltage at the battery. It should be somewhere between 13.5-14.5 with the accessories turned off. If it is less than that you may have a bad connection or a charging system problem. If not you may have something staying on when the car is off. Like a light or something aftermarket wired in staying on (amps and caps are known for this as well). It still could be a problem with the new batt as well. Did it die overnight?
calvinnnnn
12-05-2014 06:14 AM
S2Kevinn
03-06-2012 06:01 PM
