car dynoed, super low number
#21
Folks, I've just found a way that you can get the incorrect ratio displayed on the screen so my idea about ratio being wrong is most likely incorrect. If they load the data but NOT the vehicle configuration, then you can get the correct graphs, but incorrect ratio displayed. Sorry about that folks. You learn something new every day!
#22
How long did it take to do each pull? It should take about 14 to 15 seconds per pull. Anything less than that and it will be low on power - anything more than that and it will but too much strain on the engine. The idea is to simulate the 'on the road' speed of acceleration. 2 seconds per 1000 rpm is a good number for the S.
#23
Here is my dynojet plot. The torque curve should be fairly flat all throughout the powerband.
Maybe the dynopack loading causes the erratic torque drops.
MY DYNOJET CHART
Add 5-10% for dynopack numbers. Also, you can add or subtract additional correction factors with a dynopack dyno manually. On a dynojet, you cannot apply the correction factor manually, its automatic and the corrections are minimal to a tune of +-1 to 3% typically.
MY DYNOJET CHART
#24
MY DYNOJET CHART
MY DYNOJET CHART
#26
Originally Posted by revto9k,Dec 3 2004, 07:47 PM
ok, their dyno graph for a 350Z with fujitsubo exhaust is in the 220s.
will add in a test pipe, and do compression test on monday, and have another dyno run.
#28
Did you call the folks who dyno'd your car? They should be able to tell you ratio used over the phone - all they need to do is load your vehicle configuration.
#29
FYI - they have the ability to save all your data to a floppy so that you can see all the details in Excel. I do this for all my customers and make it available on the web if they so desire.
www.holyrollerdyno.com
#30
I once saw an S2000 dyno at 138hp. It was a while ago, and I can't remember the dyno name/style. Anyways, if you are worried about cyl. 1 take it in to a mechanic. Better safe than sorry.
