car dives to low rpms
after a good bit of driving, my car's rpms dives to nearly 100 rpms, then pauses and it jumps back up to normal. This happens ever so often, but im scared that the s2k is going out. Any one have any info before I take it to the dealer?
I warm the car up to 3 bars before driving, and 5 mins after driving I would hit VTEC,
should I change the oil to see if it helps? Oil was changed 2k miles ago.
Does your car start to rattle when it goes that low? It happens to me when im in reverse and i have to wait for someone and the foots on the clutch and th cars in gear. Same thing in first. Very seldom tho.
k simple test
put it in neutral and rev
when the rev metre dropped to under 500, your car rattles a bit
its normal, unless it stalls...then you need to check your map sensor
some times it stalls, and Im on neutral. and when ever it dose dive to low rpms, it shakes, alot. if it is the map sensor could it be a warrantee item, or should i go buy a new one?
ultimate lurker
09-27-2013 10:35 AM
quocisflying
03-02-2005 02:28 PM
