Car is choking
Car is choking
my car;s problem started today. i press the gas all the way to the floor and it just doesn't respond right away it take a long time, when i hold the gas pedal down for a few seconds the rpm starts to build up, but while building up it misfires like crazy...........
it idles just fine, there is no check engine light either..... it will drive for like two seconds then it will just not accelarate anymore even though gas pedal is all the way to the floor and it just idles normal.
i checked the spark plugs. switched them for another ones and still does not work. i push the gas all the way and it wants to die , plus it misfires... the car won't move at all. even though it idles perfect.
Originally Posted by ShiftGearAP1,Sep 9 2010, 10:32 PM
could be as simple as the MAP sensor wiggling loose.. did you check sensor connections?
RickyLee
06-22-2016 09:39 AM
tu4nle
01-25-2010 07:59 AM
