Car bucking at cruising speeds.
I think I found the problem with the car
The Secondary air pump hose was just about to come off the air pump valve on the back of the intake manifold.
Have not had a any sort of problem since I fixed that hose connection.
Pulled the ECU codes none stored and none pending.
Also did the MAP TSB and put a zip tie around it.
mnr vortx f20c
11-06-2011 08:27 AM
