Car bounces left to right on highway !?!?!
Didn't you say you were running 32 PSI cold, in all four tires?
If so, given your rim widths, I don't think under inflation is the problem, but you could always increase the pressure a little to be sure. Try adding another 4 PSI (36 PSI cold) to see. I suspect that will be far too high, so assuming it doesn't help, you might also try dropping the pressure a couple pounds (to 30 PSI cold) just to see if it makes any difference.
Tire balance usually causes a vibration rather than making the car jerk jack and forth, but it DOES usually set in between 50 MPH and 70 MPH, so maybe ... I just don't see how balance could make the car self steer.
Another thing that it may be is when the mechanic put on the springs he didnt check to see which ones were for the front and rear... because they all looked the same .. maybe he put one front and one rear in the front??? i think i may have to double check that also cuz i know the spring rates are a bit different .... can that be the cause ?
If you didn't have enough forward caster, that would most definitely cause big time darting in all directions.
There are a number of reasons that can cause these symptoms. Incorrect toe settings, wheel alignment is out of square, worn out lower control arm bushing'(s) will make any car bounce to the left and to the right all over the road at freeway speed.
Prolly in mosts cases an alignment will cure most of the symptoms, but if car gets aligned and still doing the same thing, there are part'(s) that are worn out and need to be replaced.
Originally Posted by RACER,Jul 23 2007, 04:28 PM
If you didn't have enough forward castor, that would most definitely cause big time darting in all directions.
A good alignment man will check for worn bushings, excessive play, and so on, during the alignment.
Always a good idea to get a print out of the before and after alignment specs (whenever possible).
Have you steering rack checked. S has power assisted rack and pinion steering that can be adjusted. Mine had similar symtoms once and that turned out to be the problem.
