Car is Acting Retarded!
Old 11-23-2009, 02:19 PM
  #21
FISH22's Avatar
Kitt, the total rear toe does seem a bit high. Pretty sure I'm running a tad under 1/4" total out back.
Old 11-23-2009, 05:34 PM
  #22
bgoetz's Avatar
sounds about right, I have modified the euro alignment a bit and added about 0.3 degrees of negative camber to the front (mainly because I made the mistake of just replacing the rears with tires that I "thought" were comperable to the fronts, well the fronts are a bit hard from age have less grip ). So I am around .20 degrees of total toe in the rear, which IMO is perfect for a semi-aggressive streetable alignment. Any more than .25ish makes these cars numb and a bit unpredictable at the limit IMO, plus you are going to get some pretty uneven tire wear.
Old 11-23-2009, 05:52 PM
  #23
S2Kitt's Avatar
(Not being a smart ass)
So my alignment just may not be suitible for the new tires I put on. But may have worked for the old set? I guess it makes sence. explains the immediate change in the car.
bgoetz
If you don't mind sharing your numbers for your alignment I would really appreciate it
an thanks for you insite
Old 11-23-2009, 05:54 PM
  #24
[APtwo]'s Avatar
Originally Posted by S2Kitt,Nov 20 2009, 04:44 PM
Before car use to grab the road like your mom use to grab you when you acted up in public.
Old 11-24-2009, 04:14 AM
  #25
//steve\\'s Avatar
I'd start with the alignment. Just put the toe at factory specs. The amount of camber looks fine to me. That isn't too much for street tires. I run more camber than that on crappier tires and my car feels awesome still.
Old 11-24-2009, 12:14 PM
  #26
SlipAngle79's Avatar
I don't believe you can press the old bearing out and press it back in - I seem to recall the bearing and hub design calling for a new bearing assembly once removed. I've replaced 2 of them myself and always used new bearings when pressing back in.
Old 11-24-2009, 02:11 PM
  #27
S2Kitt's Avatar
thats what I thought. but when I lift it an shake the wheels they don't flex or wobble or anything really.
CaliPatriot88
02-05-2015 09:45 PM
The Shocker
12-16-2010 04:10 PM
gilwood
12-03-2009 04:54 AM
mindaddy
09-10-2005 05:15 AM
gonezo
11-14-2003 08:12 AM
Quick Reply: Car is Acting Retarded!
