cant put my 02 s2k in reverse?
Old 02-20-2013, 04:39 AM
Sileighty's Avatar
The clutch is loose? Have you checked your fluid yet?
Old 02-20-2013, 06:21 AM
uriloco's Avatar
That's exactly what it is -________-
Old 02-21-2013, 03:13 PM
tylers2000's Avatar
So what is the solution to this problem? I have the same symptoms... I'm unclear as to what the solution stated here was.
Old 02-21-2013, 03:46 PM
jason4207's Avatar
My clutch master cylinder went out, and I had similar symptoms. Replaced it, and rebuilt the slave master cylinder while I was at it, and it's been golden ever since.
If you see a drop of fluid leaking out the piston/cylinder behind the clutch pedal it's time to replace the master cylinder.
Old 02-21-2013, 03:59 PM
tylers2000's Avatar
I replaced the Clutch master cylinder about 25k ago.
Old 02-21-2013, 04:48 PM
tylers2000's Avatar
also, I don't see that any fluid is leaking from either the slave or the master. I just replaced the clutch. The fluid looks kind of dirty. Could that be it?
Old 02-22-2013, 05:44 AM
jason4207's Avatar
After the Clutch Master Cylinder was replaced was the pedal adjusted correctly with a little bit of play at the top? When I bought mine the previous owner told me the clutch had been replaced. The clutch felt very tight throughout it's travel, but I figured it was a beefier clutch or something. It was an incorrectly adjusted pedal that was the problem and it blew out the CMC in less than 10k miles.
The clutch fluid gets dark pretty quickly in these cars. I doubt that would cause this issue, but it can't hurt to replace it. Try to remove as much fluid as possible out the top using a turkey baster or similar before flushing/bleeding the rest.
Old 02-22-2013, 08:52 AM
Sileighty's Avatar
Woot, glad to have helped. Always start with the most simple solution first.
Old 03-13-2013, 04:57 PM
tylers2000's Avatar
My issue was the pedal adjustment. It was WAY out of adjustment. I tightened it up, and now the clutch is dis-engaging fully.
LiveFast
09-29-2014 08:58 AM
planeman01
11-30-2011 02:50 PM
MaxV_
10-04-2011 11:32 AM
jaehoppa
06-15-2007 05:25 AM
s2kpr01
08-12-2006 12:54 PM
Quick Reply: cant put my 02 s2k in reverse?
