Cant Peel Out?????
Wheel hop=something is going to get broken
Something broken=abuse
Be nice to your car. Go with legal bill and xviper and if that doesn't work go see the dealer. Just let him know that the car hops when you mash the gas off the line. Leave out the dumped clutch part.
You may want to look and see if Honda remembered to remove a rubber spacer they place between the springs during transport from the factory. They forgot to remove one from mine and, until the mechanic who discovered it removed it, I had similar launch issues.
Wheel Hop
An undesirable suspension characteristic in which a wheel (or several) moves up and down so violently that it actually leaves the ground. Wheel hop can be caused by many problems, including excessive unsprung weight, insufficient shock damping, or poor torsional axle control.
I've always refered to it as axle tramp.
carful i had a clutch issue with launch so i upgraded to street/race clutch ($450) dealer paid all but partial part, now car launchs like a champ from 3500rpms but i did it at 6000rpm and no i am replace the diff took 4 teeth right off the ring gear.....now i am putting in 4.77 ($800) oh ya forgot i had to get my tranny rebuilt ($2400) first after that launch oh an i pitted my cv joints ($600).......so a lucnsh can set u back. So now i am at $4250 for that launch omk it was more like 7000rpms........point is that car is deffinatley not a dragster.....but now i have an S2000 with exedy clutch and 4.77 gears for only $4250 quite a bargain huh......man it burns them now......lol
That noise is more than likely the LSD locking, unlocking, locking.. I suggest not making it a habit. The S2000 wasn't designed to be driven like that. It's not a 1/4 mile car.
Originally posted by Swiftvision
How do you know when you took teeth off the ring?
A couple .................... CLUNK ........... CLUNK ......... CLUNK.
A lot ................. If you've parked it with the missing teeth matching the other gear, you'll just sit there next time you try to move.
