Cant Peel Out?????
Cant Peel Out?????
So here's the deal...if I rev the car up too 6K and completely drop the clutch......the car violently bangs around....and hops down the road, with this horible loud "BANG BANG BANG" and everything shakes to sh!t. The whole car vibrates like crazy.
Is this normal? If it's not what am I suposse to say to the dealer? I can't peel out?
Originally posted by Swiftvision
I can't peel out?
I can't peel out?
It sounds to me like you may have damaged your differential.
The one and only time I did a 6k dump was I sidestepped the clutch and it just connected. I left some rubber and the car just smoothly accelerated. I would figure hopping around would be a bad thing and could symbolize a more serious problem.
I would guess that if the car isn't acting normal when you are trying to do something, stop trying to do that "thing" until you can get the car looked at.
"peeling out" is just the clutch engaging and the wheels slipping, which is better than the clutch slipping, or smoking it in general
Yeah, the S2000 should be able to launch, but on a circuit course how many times do you have to do that in a race? Just when you leave the pits or at the start. Most of the time races are rolling starts anyways.
The clutch / differential setup in the S2000 is weak in comparison to a car like the GTO, or the Corvette, or the Viper SRT-10. People who own those will more likely go to a straight line drag strip and not a circut.
If you launch the S2000 you are taking a larger risk of damage than perhaps in other cars. Either wait for VTEC to pull you out of the hole, or you run the risk of cracking or destroying the rear differential, or smoking the clutch.
Now with upgraded equipment, you'll be more likely be able to launch more regularly and more consistently.
When you dump the clutch, floor the gas pedal and see if doesn't launch smoothly. It sounds like you are holding it at 6000, dumping the clutch, but trying to keep your foot positioned at the same point on the gas pedal. As the car pulls forward, you involuntarily lift off the gas, the car then bogs, you go forward and you hit the gas again. This can be repeated many times and it feels like the car is jumping around. Hold to 6,000, dump the clutch, floor the gas. If it still hops around, something is wrong.
Check your tire pressures. It's easier to "peel" out with higher pressures (35 -36 psi). The other possibility is that you ain't doing it right.
In any case, I'm sure your dealer will be rubbing his hands together and have dollar signs in his eyes fairly soon.
