Can't get shift knob back on
Apologies for starting a new thread, but I did a search and couldn't come up with much.
The stock shift knob in my car has come off, and I can't get it firmly back on. When I attempt to screw it back on, it mostly slides down the shaft and doesn't really "catch" on the threading. I'm really not very mechanically inclined - is there something I need to do so that it won't simply slide on/off? I'm guessing superglue isn't the answer.
Thanks for any advice,
Justin
Justin
'slides up and down' the stock knob?! it sounds as though the threads inside the knob are all gone..if thats the case, you either have to get it sleeved with a plastic insert or get a new knob
The threads may very well be gone - I'll check tonight when I'm able to see the car again (been a few weeks). If so, is this plastic sleeving available from the local dealer without buying a new shift knob?
Also: what's this about a lock nut? I know there was some tiny little "button" somewhere on the shifter, but I wasn't aware it had much to do with this...
Thanks again for your help.
Justin
Justin
I finally saw the car again last night - the threading was definitely stripped. However, after looking at eBay, I've come to discover it's not the OEM shift knob. I'm just probably going to end up buying one of those.
Thanks for all the info!
Justin
Justin
Justin
Justin
Justin
Justin
