CAN'T GET REAR TO ALIGN
i few weeks ago i lost control in the rain and got the whole car up on a curb, not much rim damage but some. I got it on the alignment rack but i could not get the rear in spec, so i know i need to replace some parts but i cant see anything bent, both sides are toed in 2 degrees, and have -2.5 degrees camber. and that is even when the toe adjustment shim is at its lowest point. i also have bearing noise so i know i at least will need a hub, spindle and bearings, but i need to know what part (if damaged) would be most responsible for the toe in the rear? cause nothing looks bent and i dont know what to buy. someone please help cause its just chewin up my tires they are almost bald, i've lost almost all my tread in less than 4k miles.
