Can't Get perfect TDC
This is the other link i was talking about with the same situation.
https://www.s2ki.com/s2000/topic/957...check-the-tdc/
Is it even possible for the crank pulley/crank trigger wheel to separate and move out of time if you were cranking on it with hand tools to remove the pulley's bolt??
Is it possible for timing to go out as the miles pass by?
It was fine as is for a while. I swapped retainers to AP2, new OEM valve stem seals, ACT/OEM combo clutch, and new upgraded oil jet banjo bolts installed a few months ago. Car went well ever since then. Tuned on AEM Series 2, NA stock engine with exhaust bolt ons. Last Saturday while driving it suddenly started misfiring badly and hesitating between 1 to 3k rpm. It never switched off but made sputtering noises several times when I was on light throttle. When I gave it more throttle it pulled smoothly from 4k up to about 6k where I tapped off. I looked under the hood and nothing came loose so I limped home like that. Now the car won't start. It just about starts then sputters and switches off. Battery almost drained at this point. Could timing have gone bad and done this?? AEM reported a timing error for a while. VTEC solenoid screen is super clean. Oil changed recently and always topped off. Coil packs are new AP2 Denso 673-2301.
Compression test numbers? Leak down test?
Don't have a tester. I can get one though. I am wondering if the valves tightened up too much causing bad compression on multiple cylinders. I will get in there to check and confirm
P.S. Based on others' experiences a bad FPR can cause this issue too. Maybe mine is K.O.
bluemetals2k
Member S2000 Classifieds and For Sale
43
07-03-2010 10:32 AM
