Can't get into first gear
Today i was driving home from work and i come to a stop, when i start to go again i try to go into first and it just wouldnt happen so i take off in 2nd. a few hours later i sit in my car and no mattr what it will not go into first. its a my05 and was wondering if anyone has any ideas on what could be wrong before i get a chance to call the dealer.
never had that problem on my my05, but on my old beater 4 runner i used to have, sometimes it wouldnt go into 1st gear so i would clutch in press it up to the gate and slowly release the clutch and it would "suck" it into gear. You might try the dealer though, on a new car like that, it shouldnt do that.
-Ian
-Ian
The gear is stiff when cold. I found that I could only put in 1st gear when car is not moving and engine idle. If car is moving and you want to put to first, give it a little gas to say 2k rpm, then it slides right in.
Again, it is necessary only when car is not warmed up yet.
im having similar problems as well, but its in all gears; might be a tranny issue. Sometimes it wont go into gear period when the car is on; off i can shift into all gears. I literally have to sometimes force that shit in to the point where i think im going to break something. I really just have to get lucky when it goes into gear now. Car is MY00 with 130K miles,lol, but clutch does not slip at all;checked that as well, just not engaging really.........any help?? Changed all fluids, re-bled the lines, searched all over, but no real answers just yet........Thinking i might just need a whole new transmission, but trying to avoid that.
Also, with that many miles on the car, how old is the actual clutch? Has it been replaced lately. It could also be worn to the point where it's grabbing badly due to being close to the rivets.
