cant feel vtec shift.
Old 01-24-2010, 12:27 PM
deathsled's Avatar
where are you from anyway? It looks like you're in the US but we never got CTRs here......
Old 01-24-2010, 12:34 PM
JuicedS2K's Avatar
It's engaging, you are just still in the process of realizing the s2000 is slow as hell.
Old 01-24-2010, 02:51 PM
Tech7427's Avatar
you dont suppose to feel a kick when vtec engages..
its suppose to provide a smooth more linear powerband...
Old 01-24-2010, 03:33 PM
ZDan's Avatar
Agree^^^. The more VTEC "kick" you feel, the worse. Ideally, it would shift over from low-rpm lobes to high-rpm lobes when power/torque on either is identical. Hence, ideally, NO kick whatsoever.
Old 01-24-2010, 04:08 PM
QuagmireS2k's Avatar
Smooth is better. The jolt means your just making less power till then...
Old 01-24-2010, 04:49 PM
2slow2Bfurious's Avatar
i've never owned a honda before this one, so i might not be the best judge. I can feel the v-tec kick in yo, but never has one of my passengers been able to distinguish the kick. It's somewhat subtle.
i suppose it's a good thing u didn't get an ap2, the kick is even more subtle.
Old 01-24-2010, 07:05 PM
iam7head's Avatar
after owning 2 type-R you should know the massive vtec rush is 90% psychological
on the serious side, 2 liter is about a quart low, which isn't that bad but if you feel bad not checking it out then do a leak down and compression check
btw i am still waiting for my massive vtec kick after three honda
Old 01-24-2010, 07:24 PM
kaosaelee's Avatar
VTEC jolts the most in 1st gear. then 2nd... and so no. but will not most likely not feel it in 3rd gear and after
Old 01-25-2010, 11:06 AM
davidc1's Avatar
The one poster was right when he said a lot of it was psychological!
Also, realize that if you're previous cars had any air intakes installed, that make the sound change much loader, which increases you butt dyno feeling.
Most S2k owner don't have an air intake cause it really doesn't add much hp.
Old 01-25-2010, 07:22 PM
justind's Avatar
i had a prelude, and you can feel the kick in on those way more lol, i know what youre talking about
its just really smooth in a s2000
Quick Reply: cant feel vtec shift.
