Can you change where you clutch disengages?
So can ya? Mine disengages literally once the peddle is pushed 1-2 inches in and I am almost worried about it possibly being too close to when the peddle is all the way out.
ummm you can rebleed it and see if that helps..basicly you can get all the air out of the system and that might change it.. maybe your pressure plate is worn
Assuming there isn't a PROBLEM with your clutch system (friction disc, pressure plate, slave cylinder, master cylinder) you CAN in fact adjust the point at which your clutch engages. If you refer to the manual, there are directions for doing so. It involves getting under the dash and loosening a bolt or two, making adjustments and retightening the bolts.
Perhaps someone can link a DIY or Helm excerpt.
Its not zero resistance, just about half an inch of travel before you actually feel the clutch I guess is the best way to describe it. Thought it was normal but I remember seeing billman saying there should be no free play. Isnt free play what im describing?
Sure. I've always had the same. And I've also got a brand new clutch system (Master/Slave, PP, friction disc, flywheel, throwout bearing, etc.) and had it adjusted professionally by an experienced mechanic.
If I'm not mistaken there's nothing wrong with that. Anything MORE than that could be a problem. For all intents, it's basically zero free play and seems like normal for the non-NASA specs of the mechanics of the pedal.
completly off topic, venom, love your avatar. megan fox is the hottest,,, since i am apperently a guest i cant post a pic kudos. as far as the clutch goes, im trying to get my girl used to it. crushing me and the s2 but they have to keep trying, and i die a little inside, but worth the wait. i hope, peace, keith
Thanks SKEITHR she IS the hottest .. man I know the feeling when your girl drives your car and completely F*** your clutch up! not good
u can post a image just upload it to photolava.com and then post the link here @!!!
