Can we safely run our cars with 11.5 compression ratio?
Absolutely. First, Honda gave us 11:1 to provide some leeway for bad gas or even the emergency requiremtn to run lower octane. However, with a good combustion chamber design, 11.5-12:1 compression is well within reach on 92-93 octane. I've run 11.5:1 on a B18C1 engine (modified) with no problems whatsoever. Toyota runs the Celica GTS at more than 11:1 compression ratio as well.
Basically, you remove some safety margin, but as long as you don't run lower octane and keep your knock sensor, you'll be fine.
As another example think about the effective compression ratio on a supercharged S2K running 6 lbs of boost.
That said, it isn't worth the effort to pull the head just for a compression ratio change. If you plan on changing cams (which means you've done half the job required for pulling the head) or plan on porting the head, then go ahead and up the compression.
UL
UL
If you can get 100-octane, you can try. Not betting on it to have no problems. Export and local engine parts differ frequently with the slightest difference sometimes unaware of the common tuner.
I have though about this frequently.
Chris, it's not clear to me that ROW S2000 have 240HP and not 240PS. If that is the case, then you do get an extra 10PS.
I would also be weary about taking conclusions just by looking at the CR. The final cylinder pressure is also dependent on variables other than CR. So a 12CR maybe fine for one engine but not so good for another.
This said, I'm convinced that the thinner headgasket that JDM versions sport are the basis for their increased power, and that Honda was playing it safe in the ROW markets. For instance, in some countries in Europe 98RON is simply not available (Italy comes to mind).
This is a mod I could do for less than 500USD. and in the S2000 you usually have to pay much more to get 10 extra PS.
My question is (I know, I've asked this before, sorry!): Is opening up the top end a risky undertaking? (like in "my motor was never the same... " )
Be sure to wrap pantyhose around the radiator "in" to catch the old head gasket shavings which fall into the block when you scrape.
As far as the risk of the change.. it simply depends upon the mechanic. I have swapped heads on cars (with simpler valvetrains) many times without problems so that tells you it is not that hard. But it would be prudent to use a mechanic that is experienced with Honda/VTEC and the swap.
