Can we go to a heavier transmission fluid?
Old 01-14-2010, 07:14 AM
ECale3's Avatar
^ LOL, you are a Florida person through and through aren't you? I'd still be wearing shorts and a T shirt at 50.
Old 01-14-2010, 07:38 AM
Former Sponsor
Gernby's Avatar
I tried both redline oils before trying GMSFM. Redline MTF was too thin, MT-90 was too thick, and GMSFM was perfect. I was also able to go 15K+ between changes of GMSFM without any noticeable degradation in shifting feel. However, this was with my '02 AP1. I plan to try GMSFM in my '08 in the next couple weeks.
Old 01-14-2010, 09:24 AM
cdelena's Avatar
I've tried them all and found that MT90 works best in my old tranny.
Old 01-15-2010, 11:06 AM
INTJ's Avatar
I run GMSFM, since I found MTFII gave me around 10k. but GMSFM was even smoother than new MTFII after 10k its still rougher than I like.
FWIW-I found LE (110) for the diff was too thick at 20F! This doesn't match the specs. I could actually hear the whine and it would clunk in tight backing when cold. I'll run a winter and a summer weight from now on.
Old 01-16-2010, 03:12 AM
SpitfireS's Avatar
INTJ Posted on Jan 15 2010, 09:06 PM
LE-1605 has - or should have - a pour point of -11F.
Did the noise go back to normal after some warming up?
IMO there are 75W-110/140 oils available that will work year round for you.
What if one would just stick to the manual - as many do with 10W-30 - and use SAE 90 in the diff....
The few single grade SAE 90 oils around are dino and would have simular pour points.
Oh well...
Old 01-17-2010, 02:20 PM
INTJ's Avatar
Oh well...
Its perfect now, and it would quiet down after about 10 min of driving. Nothing wrong with the 90, just that the pumpkin is tiny and only air cooled. Its a really robust diff, but it is subject to wear under hard use.
Old 01-18-2010, 07:06 AM
Saki GT's Avatar
Regarding GMSFM, I heard there is a Pennzoil equivalent - does anybody know about that?
Old 01-18-2010, 07:19 AM
Saki GT's Avatar
Originally Posted by SpitfireS,Jan 14 2010, 05:22 AM
I'm using the ATM now and I like it, smoother than GMFSM.
Time will tell, so far only 2500 km.
But ATM is only 9.6 cSt.
The Redline MT-90 has specs closer to what you are looking for IMO.
So does the Amsoil MTG (75W-90 GL-4).
This is what you recommend Spitfire?
Amsoil: http://www.amsoil.com/storefront/mtg.aspx
Redline: http://www.redlineoil.com/product.aspx?pid=46&pcid=7
Old 01-18-2010, 09:39 AM
SpitfireS's Avatar
Saki GT Posted on Jan 18 2010, 05:19 PM
Yes, those are the 2 oils I was talking about.
Those are the 2 I would try if I was in your situation.
I also have to agree with camuman, if it gets cold where you are it might shift until it warms up.
Just to stir things up a bit have you tried the Amsoil MTF yet?
According to the Pennzoil website its dino oil.
Who knows how shear stable it is.
INTJ Posted on Jan 18 2010, 12:20 AM
Nothing wrong with the 90..
My point was that the manual does not mention using a thinner gear oil (for the diff or transmission) in colder climates, as they do with engine oil.
IOW, they probably think its no problem.
Btw.. LE-1605 is within 1999 SAE 90 gear oil spec.
Old 01-18-2010, 10:32 AM
Swiftoy's Avatar
I have tried the Amsoil MTF and found that when the car is cold it shifted a bit hard. I have since changed to the Honda MTF2 and find this to be the best for me so far. As cheap as it is and the amount of miles I put on in a year it doesnt really matter how long it lasts.
I'm wondering if mixing the two would yeild positive results.
Quick Reply: Can we go to a heavier transmission fluid?
