Can a valve cover gasket leak cause a hesitation?
I was driving home tonight with low RPMs no vtec or anything and while accelerating I got a sudden shock when the "S" stalled on me for a very brief moment, about as long as it would take you to say STALL (complete loss of power). It happened on two different occasions on the way. I changed the plugs about two weeks ago (OEM plugs )and saw a little oil residue on cylinder #4 plug. I also looked tonight and noticed the front passenger side bolt that holds the valve cover on has been seeping oil down the side of the cover as well. Could enough oil be getting inbetween the coil and plug to cause this hesitation? Vtec is strong and have no other problems. Im sorry if this has already been answered but I couldn't find any particulars to this sort of problem.
yes there was a little brown oil ring burnt around each plug. So I ordered a valve cover gasket and the spark plug ring gaskets. I also replaced the plugs again too. Hopefully no more problems!
Driv300mph
06-07-2009 08:09 PM
