can tire pressure differences really cause this?
Hello, s2K brain trust:
Here's the Setup:
MY2002 s2K
all stock, 20K miles
just (500K miles ago) put in new re750 in the rear (245/45/16)
s03 in the front, worn almost down to the wear bars on the inside, lots of tread left on the outside
Went on a trip to Yosemite last weekend and noticed the car was behaving strangely. Bump steer at lower speeds, very squirrelly front end, not the usual confidence-inspiring handling. nothing seemed to be amiss (not that i would necessarily know...), except for different tire brands.
checked tire pressure - 35lbs in left front, 32 lbs in right front. rears at 32 lbs both. Take some air out of the left front, and she is back handling like a dream.
Does this make sense? would 3 lbs of pressure difference make all that much difference in regular driving, or am i crazy? Could it be that the differences between tire brands from front to rear magnified this?
Thanks.
Here's the Setup:
MY2002 s2K
Thanks.
different tire brands? Are you kidding? Different tire brands can mean different sizes i.e. 15/45/205s for one brand can and most likely is different than another brand of 15/45/205. Also the tread pattern is obviously different which makes the tires handle differently. I would get all 4 tires the same brand. You could have some serious under/over steer and be very dangerous near the limit.
[QUOTE]Originally posted by avs2k
Here's the Setup:
MY2002 s2K
Here's the Setup:
MY2002 s2K
What I am saying is they "should" be of the same make/model and rotating tires (side to side is the only option on this car), is a way of maintaining even wear on the tires.
I can't say if things would improve for you since you have different tires on the rear and I have not let my insides wear down that far prior to swapping side to side. IMO it would at least be a step in the right direction for you.
hotmayo
05-13-2005 05:30 PM
