Can someone post their Mugen header and exhaust dyno
Originally posted by cdelena
There is a comparison of several cars in this thread but I think mine was the only with the Mugen header and exhaust.
https://www.s2ki.com/forums/showthread.php?...?threadid=38953
Do you think the TB made/makes a noticeable difference? Did you remove the heat shield or did you coat the header. Also, do you think they work best together. I have noticed that several members only get the header.
Thanks again ...
The TB improved throttle response, but all the experts tell me it adds no power. The Mugen comes with a heat shield that is installed. I bought the Mugen exhaust because I like it (got rid if a HKS that basically performed the same with more noise).
Originally posted by Jenner
Here is just the exhaust, not sure if this helps you or not. Getting the headers put on soon.
Thanks for the info.
Jaysom, I posted my dyno runs with comparison between stock, Mugen header and exhaust and finally H/E/Mugen ECU and Injen CAI on a thread labeled Mugen ECU installed. Have you seen it? It's closed now, but the dyno scans are still up to view. I hope it helps you.
[QUOTE]Originally posted by 9906
[B]Jaysom, I posted my dyno runs with comparison between stock, Mugen header and exhaust and finally H/E/Mugen ECU and Injen CAI on a thread labeled Mugen ECU installed.
Exhaust alone will only give you maybe 2 hp. If your lucky.
Mugen does not say that the Exhaust makes HP. The headers they do. Though when combined make a little more than headers alone.
