Can I tap the red V-AFC wire for power?
I am installing the ESM for the Comptech Supercharger and I need a place to tap for power for the ESM. Is it possible to use the red wire running from the harness to the V-AFC unit for power? I really cant think of anywhere else to connect it and I have the accessory fuse already used. Thanks!
Or just tap into the wire that you have already plugged into the accesory fuse outlet.....
Or use the 12v (red) wire on the vafc....
Or use any other 12v wire you can find.
