can a bad cat cause a loss of power?
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
I couldn't pass smog forever, found out I had a bad cat. Honda is putting a new one in for me. I noticed that my ap2 felt slower than the ap1 i drove before, I was wondering if a cat can cause any difference in a loss of power? Would it be minimal or significat?
forever? It depends on how bad the cat was. It might not have at first, but after some time, a disloged cat may start causing some blockage.
Tell us how it is after you drive with the new cat and sensor.
Former Sponsor
It depends on how the cat failed; if it's internally melted, or otherwise clogged with carbon deposits, it could be a serious exhaust restriction, and could greatly limit your power.
I assume the car is also throwing a CEL - in this case the ECU might be limiting power, or you could also have a dirty or non-working oxygen sensor, all of which could reduce performance.
Fastlane
10-16-2001 08:59 AM
