camber settings on the front
Old 02-24-2008, 05:17 AM
c32b's Avatar
Default camber settings on the front
Hi guys, would like to have some sharing on how change in camber setting on the front helped/hampered performance.
I increased my camber on the front from stock and found my car braking quite differently with a tendency to lock up earlier. I'm on stock suspension btw. Any thoughts on this?
Old 02-24-2008, 12:45 PM
99SH's Avatar
What are your current Toe and Camber settings?
Old 02-24-2008, 05:01 PM
c32b's Avatar
Toe is about the same as stock. front camber is -2 deg.
Old 02-24-2008, 05:21 PM
99SH's Avatar
Generally speaking negative camber does adversely effect straight line braking. I too have -2 deg camber up front, as do many others here, but don't seem to see this as an issue. The handling did improve greatly which is what I was after mainly.
When you say lock up earlier, do you mean ABS is kicking in earlier?
Old 02-24-2008, 05:47 PM
c32b's Avatar
hi, just to clarify some points...are u running stock tyres?
Old 02-25-2008, 10:26 AM
CaptainMike's Avatar
Think about what camber does... contact patch will be smaller (driving in a straight line) hence braking distances (straight line) will be increased.
Old 02-25-2008, 04:51 PM
c32b's Avatar
thank you for your comment and before i posted this thread i definitely did know the effect that increasing camber will have on straight line braking in a general sense.
what i was hoping to gather was real world feedback on exactly how much change there was when camber was increased especially with stock suspension and stock tyres.
i get much more tyre squeal and enter ABS a bit earlier than i would have expected with such a change. Would like to know if anyone has had similar experience?
Old 02-25-2008, 05:30 PM
Obviously I have no way of knowing the knowledge level of anyone posting here. You seriously would not believe some questions that get asked. What pressures are you running? Have you tried reducing pressures? Might give you a 'tad' more grip up front. I think the stock AP2 setup starts out on the pushy (understeer) side of neutral. Going to a 225 or even a true 215 (the OEM's have a tread width nearer that of a 195) up front.
Everything in suspension setup is a trade off, so you need to decide what is most important to you.
Old 02-25-2008, 05:49 PM
99SH's Avatar
I'm not on the stock RE050 tires, but am running 36/32 psi cold.
Old 02-25-2008, 08:01 PM
c32b's Avatar
[QUOTE=CaptainMike,Feb 25 2008, 06:30 PM] Obviously I have no way of knowing the knowledge level of anyone posting here. You seriously would not believe some questions that get asked. What pressures are you running? Have you tried reducing pressures? Might give you a 'tad' more grip up front. I think the stock AP2 setup starts out on the pushy (understeer) side of neutral. Going to a 225 or even a true 215 (the OEM's have a tread width nearer that of a 195)
Quick Reply: camber settings on the front
