Camber Question??
Camber Question??
I've lowered my S with KG/MM Race springs and my rear camber is -2.2deg. Can I bring it back to spec (-1.5deg)? What's the typical camber adjustment range on our cars?
Thanks!
Thanks!
that's about as far positive as it will go. wait about 10 days after you install the springs to allow time for them to settle - then go in for an alignment to check on them. there will be little, if any, difference if you just had an alignment.
a good aggressive alignment is around 2 degrees in the rear anyways. the "race springs" are just as they are labelled, for racing, which provide an aggressive camber alignment when the car is lowered.
I'm kind of lost, as some people have posted before and after alignment values of 1 deg change. Does our car have this capability to adjust a whole 1 deg?
CyBerNeo
05-24-2005 02:50 PM
