Camber maxing out very low?
Any thoughts on what would cause camber to max out exceptionally low? Like, -1.5* on the rear left, -1.3* on rear right, -0.9* on the left front, -0.8* on the front right.
Not sure if it's the people doing my alignment who just don't know what they are doing, but the guy showed me when he was adjusting the rear eccentric bolt how he got to a certain point going up then it started going down.
Caster adjustment in the front will affect your camber also, in the rear I'm not sure if the toe adjustment affects camber
If you're at stock height then those numbers don't seem unreasonable
Yeah if the eccentric bolt is at at its apex then you're just not going to get any more. How much camber are you trying to get? If you lower the car you'll get a lot more camber potential. I'm lowered about an inch and a half and my minimum rear camber is over 2 degrees.
Caster will affect both camber and toe up front. Less caster, more static camber, more caster less static camber but more dynamic camber. In the rear Toe should be adjusted by turning the eccentric adjusters in opposite directions first, then tightening the toe arm, then using the camber adjuster to dial in rear camber. This can affect max camber in the rear, but another thing that can affect that is seized bushings.
One way to know, is if you can remove the adjuster bolt. Also, alignment racks have to be calibrated from time to time. I've seen different places, give different readings for the same alignment.
Yeah, a friend of mine got his alignment done at a place close to me, and they were able to get his on spec, even with an aggressive alignment and being lower than myself. I'll probably head over to there.
Received 1,375 Likes
Wait...which way are you trying to go with the camber adjustment? Do you want to go further negative? Or are you trying for 0 camber or positive camber?
Maybe the alignment guy was confused if you used the terms "max" and "exceptionally low", and "negative" all in the same sentence.
Max is high. Low is low. Negative is low. He was probably turning the wrench in circles in confusion
When I paid people to do my alignments I just wrote down on a piece of paper what I wanted, and told them to get as close as they could. Usually worked out.
