Camber Adujustment How-To Questions.
I am looking for instructions on how to adjust alignment on S2000. I want to adjust my alignment but I could not find any info. I am going to DIY this. I am in environment in which alignment machine is available (automotive tech student) so I can DIY this. I just need instruction on it. Any info greatly appreciated.
Thanks
Thanks
- w0w! I was thinking the same thing today when washing my car...
- I thought about how much neg. camber I have on the rear...
- I just wanna adjust my rear all the way positive..
Originally Posted by CoralDoc,Nov 17 2004, 04:11 AM
I strongly recommend that you obtain a Helm workshop manual. Adjusting the alignment in the S2000 is no trivial matter. For example, one of the front adjusters affects camber and caster and it's important to not go over-center with the excentric lobes on the adjustment bolts.
Originally Posted by p0pe,Nov 17 2004, 02:01 PM
I'd have a proffessional do it... not enough rear camber = major oversteer
- but im so low, it probably has to be adjusted a lot... im pretty sure it can only go so far...
