Cam swap alignment...
Pic is kinda blurry...but it looks like the timing marks are lined up. So long as the cams aren't 180 degrees out, that should be fine.
Don't forget to attach the ground at the back of the head or the car won't start.
Originally Posted by Slows2k' date='Dec 30 2008, 11:03 PM
If the car has a stock PCM and started the cams are installed correctly.
It will not run at all if either camshaft is off 1 tooth with a stock PCM.
Last time I had to do 3 times to get it right.
That sucked
Originally Posted by carrera4' date='Dec 30 2008, 09:43 PM
usually the intake line is a little higher than the exhaust.
