Cam position sensor plug
Hey guys, I need the harness-side plug for a cam position sensor. Is there an online retailer that sells the plugs (preferrably with a wire pigtail that I can splice into the harness), another non-engine connector on the car that uses the same connector, or another car I can find in a junkyard to pirate the connector out of?
Thanks in advance.
Thanks in advance.
Pulled the female side of the connector and a pigtail from the solenoids on the harness that runs power to the passenger's side underhood fuse box. Just confirming the position for anyone who needs the info in the future.
You can also order all OEM harness connectors here: http://www.cycleterminal.com/motorcycle-connectors.html
mroverkill
09-16-2015 06:08 PM
