Cam lobe wear mark
Old 04-18-2012, 10:10 AM
  #31
w00t692's Avatar
Originally Posted by Billman250
s2000maniac, there is nothing showing on your cams that indicate broken retainers. Your retainer pics themselves are not clear enough to judge.
hrpfg2, your intake cam is NOT re-useable. Dont worry about the other end just now, just fix the retainers.
Exactly what i thought when i saw s2000maniacs pictures.
I see absolutely no abnormal cam wear in his pictures, i don't see how you guys can mistake how it looks. smooth polished look = normal, rough appearance = NOT normal
Now the other guys cams, they're effed, ground down from contact with retainers as said.
Old 04-18-2012, 10:58 AM
  #32
starchland's Avatar
I agree cams look fine, except one cam in the first picture post, but that could just be light playing tricks.
Old 04-18-2012, 12:11 PM
  #33
hrpfg2's Avatar
hey, you seems pretty smart about this. can you point out the differences between s2000maniacs and mine?
and cams aren't in contact with retainers btw. no body said anything about cams being in contact with retainers.
"as said" by billman250 "The retainer is rubbing on the roller rocker, and the hardened metal powder is etching the camshaft."
I am sorry but if you are only posting to make yourself seems knowledgeable, please don't post.
you are only misleading people.
Thank you for trying to help.
Old 04-19-2012, 04:50 AM
  #34
Billman250's Avatar
Received 1,398 Likes on 837 Posts
left lobe=High lift lobe in perfect condition. the lobe on the right has been etched. note the grey sandblasted appearance in the middle of the lobe.
You will also likely need a roller rocker. They are purchased as a 3 piece matched set and cannot be split up. When you look at the bottom of the rocker, you will see two triangle shaped impressions due to contact with the retainer.
Old 04-19-2012, 04:58 AM
  #35
Billman250's Avatar
90% of the time, you will not find an etched camshaft. So it CANNOT be used as a way to check for broken retainers. But if the cam is etched, you can be sure the retainer has been broken for a very long time (up to 30k miles).
So if you over-rev, then pull your cover and find an etched cam, it was not caused by the over-rev you just made. It was likely cause years ago or by a previous owner.
This is the stage where the contacting rocker levers the retainer and keepers sideways until it snaps the head of the valve off, dropping the valve into the cylinder. The valve and keepers never have a chance to pull completely THROUGH the retainer.
Keep in mind at this stage of damage, with a grinding roller and destruction around the corner, NO SYMPTOMS WILL SHOW. Not even the slightest noise.
hrpfg2 you are lucky man
Old 04-19-2012, 05:10 AM
  #36
speedjunky01's Avatar
wow pulled the cover just in time
take the cam to a machine shop they might just be able to micropolish it out, even though its base circle will be a tad smaller you will be able to compensate when you do a valve lash adjustment.
Old 04-19-2012, 06:14 AM
  #37
JohnsS2000's Avatar
What Billman says you can engrave in rock and call it LAW.
I drove my car after a slight overrev(downshifting off the interstate).. What happened was;
getting off the interstate, downshifted and began letting off the clutch, as the RPMs began to climb, I realized I was going too fast for a 2nd gear downshift and reengaged the clutch. The momentum the engine had already had bounced it over 9K for 1/4 a second. It only took a super breif over rev. No CEL, no missing, car ran perfect for 18 months before the CEL came on. about 18 months & 9000 miles later and the CEL came on. Took the car to as local shop(in Tampa/St Pete) for repair. Before taking it to the shop the compression was fine in all 4 cylinders, leakdown was good in all 4 also. CEL was a miss fire in multiple cylinders. Since the only issue I ever encountdered was this over rev from 18 months before, thats what I figured was the culprit. Sure enough, pulled the head to find 6 bent valves. Bent very very slightly but bent none the less. Valves have been replaced with new SS ones and the retainers upgraded to AP2 and the car has been running flawlessly. 1775 miles to and from the dragon as well as the driving before and during(hard miles in the Smokies) with no issues.
Old 04-19-2012, 06:40 AM
  #38
hrpfg2's Avatar
thank you for sharing that picture with us billman250.
and all the helpful info.
indeed I do feel very lucky to find out before a valve is dropped.
Old 04-19-2012, 07:25 AM
  #39
s2000maniac's Avatar
Dammit now I think I might have some bent valves
: cry:
Old 04-19-2012, 08:55 AM
  #40
w00t692's Avatar
Originally Posted by hrpfg2
Originally Posted by w00t692' timestamp='1334772632' post='21620236
[quote name='Billman250' timestamp='1334733639' post='21618693']
[/quote]
Sorry, i didn't mean that they were contacting the retainers, even my dumb ass should've known better than to say this. But you should be able to tell the difference between a properly wearing camshaft... and one that is not. I've seen pitted aftermarket camshafts and they look similar to this, except sometimes it is so extreme that the hardened rocker roller grinds the lobe down to nothing with the help of the camshaft material grinding away due to an improperly heat treated camshaft.
normal = smooth polished appearance
abnormal = pitted "sandblasted" effect as billman said.
Quick Reply: Cam lobe wear mark
