Cam Lobe Marks
If you run a catch can, it should be disconnected and the lines run back like normal if the car is left sitting over the winter, and if driven in the winter you should either do the same or empty it every time you drive it.
The issue is that moisture gets caught in the can too and condensation also happens in the can. So when left sitting, that moisture makes its way back into the valve cover and covers the cams. Over time this causes rust.
Moisture vapor will condensate on the coolest thing in the system. Without a catch can, the hot air moves from the valve cover to the intake and is pulled through the intake system and burned. With a catch can, the can tends to be cooler than the air passing through it, giving the moisture somewhere to condense. So this moisture sits in the can along with the oil that is captured. This allows for extra humidity to pass back into the valve cover when sitting.
This is why running a catch can on a street driven car is not only not needed, but not a wise choice unless you are willing to take the steps above. I never ran one until I needed to (aka started going on track and having the smoke screen issues) because of this.
To follow this up, @cosmomiller I did get a soft cloth and some engine oil and a little time to the problem and it removed a bunch of deposits, but the metal is definitely pitted underneath - given Billman and Daytona Dave both gave the same prognosis, this is hardly surprising! I've got camshafts on order from Japan, and I'm booked in with Daytona Dave mid August. Before and after pics of the cleaning attached, for others' future reference.
Before cleaning with engine oil & soft cloth
After. You can see the pitting
windhund116 (07-21-2021)
Thanks, for the update. Good luck with the swap.
Received 1,377 Likes
Hot oil goes in and is allowed to cool. Moisture builds up and is introduced back into the engine.
Generally speaking, don't install something aftermarket if you don't need it. And if you do install it...be ready to maintain it often. Its not an OEM part. You can't just install a catch can and leave it there all year and expect no issues.
A "proper" catch can is coolant heated, sealed, and drains back into the pan immediately.
A $20 home made catch can setup is a water trap.
In my opinion, no S2000 needs a catch can. Oil is metals best friend, and you are doing the engine no good by catching the oil. If you are looking to stop smoke on track, stop running your oil at a high level. In the middle of the xxxxx is the proper level.
https://www.s2ki.com/forums/s2000-ra...ation-1133707/
Rain H8R valve cover mod instead of a catch can.
Running halfway does reduce the oil slosh out of the breather and PCV (confirmed this a couple weeks ago).
Running at full caused me to have to drain my 2 small catch cans every 20 min session...and they were overflowing by the time I got to it.
However...your point that I've bolded above doesn't quite hold water (oil)? Not running a catch can on a track car doesn't mean the oil is going back to the engine. You're either catching it in the can or sucking it thru the intake. Either way, that oil is gone.
For a car that is tracked, the best solution is the valve cover baffle modifcation first. If you still see slosh, I think running a catch can setup and emtpying it often is key.
Running the oil half way doesn't totally kill the slosh. It just reduces it. You will still get liquid oil in the PCV/breather tubes.
I'm hoping to develop a heated and drained and sealed (vented only to a controlled source) catch can setup. THAT would put the oil back into the pan.
I know this stuff is extremely popular with the Subie crowd.
Both Crawford and Grimmspeed have one. My understanding is that it re-circulates the oil back to the motor. Could this be modified/adapted for use with the F20/22?
I don't know enough about how this stuff works, but what about an Air-Oil-Separator?
All jabs at those weirdos aside...
Recirculation back to the engine is ideal.
But...you'd need to either weld a bung onto the pan or tap into an oil feed somewhere.
And you'd need coolant lines to wrap the catch can to keep it heated.
And you'd need to recirculate the vent into a spot that is controlled for moisture to some extent (OEM intake?)
And you'd still need more frequent oil changes and frequent checking of the external oil tank itself.
"How come virtually no factory car comes with catch cans" is the question anyone should be asking before installing one.
Its more of a "race" part. Don't put it on unless you want to deal with problems.
this is probably the best overall solution.
I was too scared to mod my brand new (hard to get at the time) 06+ valve cover.
So I chose catch cans.
weekendwarrior44
01-19-2017 02:20 AM
