Cam and crank alignment, TDC problems
Old 07-29-2011, 12:08 PM
  #21
Del@vgs's Avatar
Checked valve clearances today - all like a charm!
The car starts only when gas pedal is pressed and has no idle...
Going to order new IAC and post the updates.
Old 05-02-2012, 11:40 AM
  #22
MrPK's Avatar
Originally Posted by Del@vgs
Originally Posted by Del@vgs' timestamp='1311882675' post='20825309
[quote name='Stratocaster' timestamp='1311879776' post='20825136']
Get a leak down and compression test. The F2x engines are interference engines and there might be a bent valve or two from the time the motor ran miss aligned. You need to rule that out first before you chase the new miss fire issue. I am surprised it started at all if the cams were not installed right. Yours is the first report I have seen posted on a motor running with the cams misaligned.
Just finished - 14.8 bar in all 4 cylinders.
The engine's healthy i suppose...
Any further suggestions?
P.S. Going to test IAC again...
But those 7 degrees of knock at idle really bother me...
Just checked IAC and passed the 1st test - when disconnected the rpms rise to ~1000
but failed the second test when blocking 2 holes in throttle body - the engine dies...
Bad IAC or Hondata IMG has to do something with that??
Dilemma...
[/quote]
Hi, I'm having also problems with idle after installing iVtec cams and AEM V2 ECU (S2K AP1). Idle jumping 1000-1700 rpm and some times engines dies. Oven 2000 rpm engine is working quite OK.
I would like to follow the DTC troubleshooting, where can I find the complete document ? Step 4, 5 and 6 are missing in the images... Thanks.
Old 05-02-2012, 01:24 PM
  #23
EagleDon's Avatar
4. Turn Ignition Switch to OFF
5. Remove the Intake air duct from the throttle Body
6. Start the engine and let it idle
BalladeSports
04-06-2017 04:03 PM
Jaspah
10-13-2016 06:54 AM
o'malley_808
08-07-2010 07:07 AM
Soul Coughing
06-28-2007 05:48 AM
Quick Reply: Cam and crank alignment, TDC problems
