calling international rescue !
Any of the international experts know if this is correct or not ? .......if you can't tell !! its the rear hub/knuckle with the wheel studs facing downwards .
thanks in advance
thanks in advance
It's not bent but there appears to be a large crack. From the top red line the first black line to the right looks like a rub but the second appears to be a crack. A crack here would lead to the angularity issue you see. It may just be the lighting but check for a crack.....
Utah
Utah
