Calling Ground Contol/Koni Yellow owners
Hi, I just got GC & Koni yellow setup. Trying to figure out how much do I need to lower the lower sleeve to make it about 1 finger gap.
Does anyone can give me some info with their experience?
If so, I would put the collars near the bottom and keep the spring on the bottom perch to see where you end up. Go from there
Received 1,367 Likes
Install the sleeve clipped on the STOCK perch position. Set the springs so that they are just touching the top hat (shock fully stretched). Set the car down and check the height.
Raise and lower it from there.
Clock your bushings before you do this, obviously.
You should only be lowering it about 1" at the very max on Koni yellows. "One finger gap" is probably more than 1" from stock.
