CAD drawing or measurements for S2000 oil pan?
I have a year 2000 s2000 engine that I need to build a new dry sump oil pan for.
It needs to be build to my specifications so I cannot buy a fabricated product.
Is there any way I can find the measurements for a stock OEM oil pan somewhere?
Then I can use the measurements to have the part where the gasket goes laser cut in 10mm aluminum.
Another idea is to buy a gasket and use the measurements into a CAD software but that will not be so exakt.
Canton Racing is building us a real baffled oil pan (a first for our car), and as such they had to take measurements and such. I don't know how they did everything, but they are building a new cast pan out of steel and Al if preferred.
Perhaps if you contact them they can help you out. Point you in the right direction....sell you some drawings, who knows?
Thanks your sharing your ideas. So there is no oem gasket?
The motor is in the car so then I will try to use 2-3 thin A4 papers and do a copy of the pan flange.
That I can scan in a A3 copier and then get into a CAD software.
Do you also run with a dry sump?
I am building something like this. (not my engine)
http://www.speedracersportscars.com.au/PRBS2K.htm
zeroptzero
12-13-2011 03:16 AM
lilbizzyazn
03-09-2006 05:33 PM
