A/C Turns off while driving
Ok..... I grabbed my manual, and was going to scan some stuff for you... BUT, HVAC has litterally 50 pages or something rediculous! Check the relays!! I cant stress this enough! Is there anything else that doesnt work? Ive had to replace my Ignition 2 relay, and the AC goes through that. There are a few relays for the HVAC controls, so... go buy a few, and start replacing. I believe they are pretty cheap! Relays, relays relays! Any problems I have had (Radio failure, ignition switch failure etc) were all traced back to 2 bad relays. When you check them, they WILL function, but are bad. The 2 that I replaced show full proper operation when tested, but are both bad. I cant explain it, but when I switched out the relays, all problems dissappeared. I hope this helps. If you need me to look in the manual for something more exact, ask and ill pull out the manual.
Chad
Chad
![](https://www.s2ki.com/forums/images/s2ki/ranks/member.png)
You can buy the FSM at www.helminc.com
All online copies are illegal copies of copy-written material
Thanks Chad. Are all the relays the same on these cars? I remember my 240 used 3 or 4 different types. Does the Manual have a part # I can refer the dealer to. Thanks.
