a/c problem
Old 05-03-2007, 07:55 PM
gt489's Avatar
Default a/c problem
today my a/c started to go realy cold then warm then really cold again then warm then cold again i think u get the point the compressor clutch keeps kicking on and off any ideas anybody
Old 05-03-2007, 08:13 PM
Saki GT's Avatar
What was the ambient temp? The coolant will heat up very hot initially as it draws the high temps from the car at first and then not cool as much as it goes through the condensers as the coolant that comes after it - that is just a byproduct of the coolant system in the car being so small, and might be your issue. It will be more noticable when its really hot out than on a warm day. Does that make sense?
Old 05-04-2007, 01:08 AM
gt489's Avatar
it was about 90 out and this is the first time i noticed the cold to warm and so on problem but i havent drivin the car in about a month and a half and i had to drive it today and noticed it had a problem
Old 05-04-2007, 09:46 AM
gt489's Avatar
anyone else?
Old 05-04-2007, 03:56 PM
jeggy's Avatar
i recomend getting a 2nd opinion on the temp going cycling from cold to warm and back and forth.
it could just be that you're getting used to the cold air and your body is telling you that the air is getting warm.
put a temp guage in the vent and check the temp difference between cold and warm. about 5 degree change is ok.
it is normal for the compressor clutch to cycle on and off.
Old 05-04-2007, 07:10 PM
gt489's Avatar
it cycles long enough for the air to get warm and the compressor and fans shut off
Old 05-05-2007, 12:36 PM
coxjajb's Avatar
My 2002 does the same thing. The air is real cold as long as the compressor is on. When the compressor kicks off, I can tell by the quality of the air. Honda checked it out for me and advised everything was working as it should. They said it was typical for the S2000.
Old 05-05-2007, 06:54 PM
R3DS2K's Avatar
also if you go wot the compressor turns off
maybe bad relay or going bad ..
Old 05-06-2007, 01:40 PM
gt489's Avatar
yea im gonna get it checked tomorrow
AZS2KDancer
03-16-2014 11:21 PM
MTNST
04-15-2012 08:55 PM
REVHIR
07-01-2009 02:09 AM
PDX S2000
11-10-2006 03:58 PM
Seks
07-13-2002 09:49 AM
Quick Reply: a/c problem
