A/C Fan question, and weird leak under trunk!
I have a 2001, and I just installed some spal High performance fans. When I cut on my A/C only one fan comes on, is that normal? I have read that the driver side fan cuts on with A/C, and the right side cuts on when it gets to temp. Just wanted to confirm!
Another question is about some weird stuff I found underneath my trunk.
It feels like rubber and it kind of wet. My car has been sitting a couple of days and it has leaked on to my floor.
Both fans cut on when the AC is running.
Thanks for the suggestions! Solved the issue a couple days, I have a walboro 450 fuel pump and it requires separate power wiring. Gas was seeping through the heatshrink on the wire that ran into the tank and coming out in my trunk and melting the coating turning it into a sticky oil substance. Good thing i stopped driving asoon as the problem arose, Lets just say I'm lucky to even have my car right now xD
Slowcrash_101 (05-06-2022)
tbl178
07-24-2005 10:37 AM
