buzzing noise from the tranny
Old 10-04-2008, 11:42 AM
MR's_S2K's Avatar
Default buzzing noise from the tranny
i have a question because my tranny is making a noise while decelerating but i found a tsb on it but the thing i put a stage 2 competicion clutch but is still making that buzzing noise what can i do
Old 10-04-2008, 09:41 PM
Mrfixit687's Avatar
Nothing, all aftermarket clutch disk has the buzz i think. Only solution is to use stock disk. Or live with it.
Old 10-05-2008, 02:49 AM
istdercollen's Avatar
^answer
Old 10-05-2008, 08:33 AM
cdelena's Avatar
The S2000 transmission sets up harmonics that rattle the springs normally mounted in a friction disk. Honda eventually contracted for a design that suppresses the vibration and thus far it is only the OEM FD's that are relatively quiet.
Old 10-05-2008, 08:45 AM
Randizzle88's Avatar
Yeah i have a after market ACT and it buzz. my car does the same thing when you are decelerating without downshifting i can hear it. its nothing.
Old 10-05-2008, 12:51 PM
MR's_S2K's Avatar
and one more tthing before i removed the driveshaft i marked it but i marked it in the wrong spot now sometimes when am decelerating i feel vibration from the rear and also when am going about 30mph and i shift to 6th gear and give it gas it vibrates too could it be that either its on wrong or maybe bent
Old 10-05-2008, 06:27 PM
why are you shifting to 6th gear at 30MPH?
Old 10-05-2008, 06:28 PM
that's why it vibrates.
Old 10-05-2008, 07:24 PM
FASTER THAN YOU's Avatar
I have the same noise,
I just just purchased the car, does that mean the clutch was changed?
Old 10-05-2008, 08:48 PM
Slows2k's Avatar
00-01 OEM clutches will loudely buzz/rattle under decel. push the clutch in and it goes away. Many of the aftermarket clutches will do the same.
The OEM friction disc from 02-08 is the quietest available.
Quick Reply: buzzing noise from the tranny
