Buzzing noise coming from passenger side door!
I narrowed down the sound to my passenger side door, but I just can't pin point the exact sound because since the door is hollow, the sound just reverberates everywhere. I have the door panel off and drove it around a few block but still couldn't locate the source of the buzzing sound.
This only happens between 4K - 6K RPMs
Any help will be greatly appreciated
I have the same problem. I have pulled the door panel off and its still there. I have no idea where it is coming from. I read somewhere that xviper had a similar problem and traced to the window track.
Someone Help.
Someone Help.
I had the top bolt for the front fender come loose and cause a horrible noise. Sounded like it was from the door though.
If anything just have someone else driver your car while you sit there and put your hand on as much stuff as possible until you find the source.
