Buzzing noise coming from engine
Old 10-01-2016, 09:43 AM
AbsoluteFreedom's Avatar
Default Buzzing noise coming from engine
Buzzing (maybe a fast tick???) noise coming from my AP2, even after changing out the TCT
Does not happen at idle but you hear it with any throttle application. Seems like its coming from the top front of the engine but I could be wrong.
Thoughts?
[media]https://www.youtube.com/watch?v=qb3eHXNuoHQ[/media]
Old 10-01-2016, 09:52 AM
Billman250's Avatar
Received 1,403 Likes on 840 Posts
Possible TCT noise, is it an oem tct?
Old 10-01-2016, 10:14 AM
Just got done replacing the TCT with a Ballade unit. Video was recorded afterwards.
Old 10-01-2016, 11:04 AM
Billman250's Avatar
Was this noise present before replacement?
Old 10-01-2016, 11:30 AM
Yes it was, the TCT was done to attempt to alleviate this noise
Old 10-01-2016, 12:38 PM
windhund116's Avatar
Received 1,540 Likes on 1,044 Posts
Worn pully(s)?
Old 10-02-2016, 02:38 AM
Car Analogy's Avatar
Received 1,470 Likes on 1,086 Posts
It sounds like its idling very high. So that makes me think maybe the engine was cold when the video was shot. So that makes me ask, is the noise still there once it warms up? Is noise any different when warm?
To see if its the pulleys like someone suggested, just remove serp belt, and start engine. Obviously don't drive around like that or run engine too long, or it could overheat. You don't even have to fully remove belt from car. Just take slack off tensioner, and unloop from tensioner pully, and just let belt hang there. That will be less work wrestling belt out then back in and tracing path around pulleys.
While belt is off, spin the tensioner and idler pulleys by hand, make sure they spin smooth and quiet.
Old 10-02-2016, 02:39 AM
Dup post creatwd by stupid forum app.
Old 10-02-2016, 06:32 AM
Yes the car was cold. The noise persists when the car is warmed up. I will see what I can do to check the pulleys. Are there any reference videos for that noise?
Quick Reply: Buzzing noise coming from engine
