Buzzing Noise In Cabin When Braking
Lately, whenever I have the top up and apply the brakes, I hear a very slight (barely audible) buzzing noise in the cabin. It stops immediately when I let off the brake pedal, but comes back when I reapply it.
If anyone knows what this could be, plz let me know.
BTW: Not sure if this has anything to do with it, but I have disconnected the switch that attaches to the brake fluid reservoir. My floatie broke and, rather than drive around with the brake light on all the time, I simply disconnected it. The fluid is currently at or very near the "MAX" line.
Originally Posted by Ludedude,Jul 20 2004, 03:44 PM
Have you checked the condition of your pads and rotors?
In your list of mods you have "Spugen Cross-Drilled/Slotted CAD Rotors"... cross drilled rotors do make a slight buzzing sound when applying the brake.. its completely normal if thats what yours talkin about...
the way mine sounds is if you brake lightly you can hear the buzzing/scratching sound of the rotors.. if you brake a lil harder you dont... had this sound on 3 cars with cross drilled/slotted rotors... wonder if thats what your hearing
Originally Posted by Spankee,Jul 20 2004, 09:46 PM
You know there is a repair kit that Honda sells for this problem, it takes about 2 minutes to do and cost less than 8 dollars. Its an updated float and a new screen for the master cylinder.
Administrator
Originally Posted by bigpurp,Jul 20 2004, 07:39 PM
Well, I doubt that's the cause here. I've had the rotors for 10 months, and only just started hearing the noise in the last 2 weeks.
